T
Tractormike
Has anybody any experience of Dismantling and/or repairing the above? As part of my Bristol Europa retrieve/repair/renovate project (going VERY slowly), I am trying to set up a reasonable array of tools, etc with which to attack the beast. I recently acquired 2 Elliot and Lake 35-ton jacks at auction (Way over the top, but ridiculously cheap). One of them works a treat, but the other has problems holding a load, i.e. it will list without a load, but as soon as a load is applied, it lifts no further - possible a seal, valve or pump issue. So I am, mainly out of interest, looking to see if I can fix it. So far I have removed the capping nut at the top, and the "up/down" valve on the side, but I cannot see my way forward from this point.
I know it is a bit of a flight of fancy and i can get a perfectly adequate new bottle jack for a relatively small cost (probably less than I could wind up spending on this) but someone out there might have a smidgen of knowledge that could turn a lump of cast iron into a useful lifter.
Any (helpful) contributions welcome
TractorMike
TractorMike
