Dumper for Rory -- Iti special - 1fwd & 3 reverse LOL
either had an engine swap or is starting backwards .. would explain a LOT of smoke .... read the description :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO:
Gecko
Gecko
Is the helix on the handle? The only hand cranked engines I've had to deal with have the helix on the crank and a pin through the handle.
Could the diff have been put in upside down?
edit: just noticed it's 4wd - it'd take some real talent to get two diffs wrong.
heritage machining
heritage machining
Some start off the cam shaft instead of the crank my old one did that had to be swung the other way my mixer does too think the idea was to get a bit more speed on the flywheel
Canal Navvy
Canal Navvy
I've known ones that had a cast starting handle with a sprung pawl that engaged with a keyed shaft on the engine.
It was always fun to turn the pawl 180 degrees and watch somebody else struggle to start it backwards 🤣
know the ones .... lift and turn :ROFLMAO::ROFLMAO:
