Johnny
Hi
I just bought a Case CX80C.
Good tight wee digger. Only problem is trying to steer tracks. 2 levers full forward no problem. 2 levers full back no problem. Also it will push with blade no problem.
When I go to steer one lever has to be in neutral before the other one will drive and vise versa.
Was reading up last night and it may be the Proportional Valve beside Hydraulic pump. ??
It may be sticking.
Yesterday while using it I come across a large Rock buried and had a bit getting it removed.
I had to Bang it a few times which obviously vibrated the digger. I moved to get a different angle at it and it steered ok and as soon as I changed direction to steer back to old tricks again. It’s seems as though flow of oil only goes to one side at time when Steering ??
Anyone come across this before? Any help much appreciated.
Thanks
It may be sticking.
Thanks
