Why will you need a diverter valve if you’ve got that spare spool?Yeah I don't have that. I was thinking to put a small 6x2 from flowfit in there, I think I am pretty close to sussing the piping too.
define small ??Yeah I don't have that. I was thinking to put a small 6x2 from flowfit in there, I think I am pretty close to sussing the piping too.
depends what's controlling it ?Why will you need a diverter valve if you’ve got that spare spool?
It has servo pipes connected, must go somewhere....depends what's controlling it ?
yeh ...... but where??? ........ pipes have the same colour/style collars on that I'd expect to see on QH plumbingIt has servo pipes connected, must go somewhere....
JCB have colour coded the hoses for quite a while now, on every hose.yeh ...... but where??? ........ pipes have the same colour/style collars on that I'd expect to see on QH plumbing
Number 13, the 6x2 diverter isn't installed. At least if it is, I can't find it anywhere. I need to look harder and find where those hoses out the block go before I get buying anythingWhy will you need a diverter valve if you’ve got that spare spool?
https://www.flowfitonline.com/hydra...-38-bsp-internal-drained-24v-dc-50-lmin-flows Like that just with little ports and just put it where number 13 is supposed to be, if it isn't there.define small ??
Yeah which is useful, except with a sort of sticky tape that seems to peel off and fade. Can suss it mostly but it is coming off on someJCB have colour coded the hoses for quite a while now, on every hose.
Thats the plan is to try and follow the colours and seeIt has servo pipes connected, must go somewhere....
I suspect the colour code thing isn’t there to help us that want to fiddle around with our machines...Yeah which is useful, except with a sort of sticky tape that seems to peel off and fade. Can suss it mostly but it is coming off on some
I would check that their internal drain isn't pressure dependent--- there is still a drain port in the body if you look at the tech PDF https://www.flowfitonline.com/search?open_pdf=1&name=SDVRN06.pdfhttps://www.flowfitonline.com/hydra...-38-bsp-internal-drained-24v-dc-50-lmin-flows Like that just with little ports and just put it where number 13 is supposed to be, if it isn't there.
