7 Tonner thumb suggestions
Yeah I don't have that. I was thinking to put a small 6x2 from flowfit in there, I think I am pretty close to sussing the piping too.
Why will you need a diverter valve if you’ve got that spare spool?
It has servo pipes connected, must go somewhere....
yeh ...... but where??? ........ pipes have the same colour/style collars on that I'd expect to see on QH plumbing :unsure::unsure:
honey_badger
honey_badger
Number 13, the 6x2 diverter isn't installed. At least if it is, I can't find it anywhere. I need to look harder and find where those hoses out the block go before I get buying anything
honey_badger
honey_badger
JCB have colour coded the hoses for quite a while now, on every hose.
Yeah which is useful, except with a sort of sticky tape that seems to peel off and fade. Can suss it mostly but it is coming off on some
I suspect the colour code thing isn’t there to help us that want to fiddle around with our machines...
It must be for manufacturing purposes
https://www.flowfitonline.com/hydra...-38-bsp-internal-drained-24v-dc-50-lmin-flows Like that just with little ports and just put it where number 13 is supposed to be, if it isn't there.
I would check that their internal drain isn't pressure dependent--- there is still a drain port in the body if you look at the tech PDF https://www.flowfitonline.com/search?open_pdf=1&name=SDVRN06.pdf
... see the spec on this one .....
6 Port Hydraulic Diverter / Selector Valve 3/8 Ports, 50l/min, 315bar 12v or 24v | eBay
" Max Working Pressure using Port L – 315Bar
Max Working Pressure Not using Port L – 210Bar "
couple more alternatives
Hydraulic Solenoid Valve 6/2 Way Valve NG06 12V DC, internal leakage incl. Plug | eBay
an 8/3 here for the price of FF's 6/2
Hydraulic Solenoid Valve 8/3 Way Valve NG06 12V DC Monoblock inc Connector | eBay
gain a service :giggle::giggle:
