O
oldchips
JCB 150LC used in a wood.
Started up, shuffled back, then forward, going up a slope and right track stops, no movement forward or back.
Swore, checked the obvious for jammed sprocket, etc, nothing.
Left it, came back, lifted track off the ground, exciting on a slope! Track would move just an inch or two forward or back, then stopped dead. So not the brakes. Had a much closer inspection of track and sprocket for foreign objects, nothing. I would have thought that getting something in the sprocket would stop one way movement but not the reverse.
Gently rocking the track forward and back and then it would move 4", then a bit more, then cleared. Ran track forward and back looking for frozen links, busted chain, anything in fact but nothing at all.
Now wondering did a tooth fall off the reduction gear.
Any ideas please?
It makes quite a few groaning noises as tracking over stumps and things, but take it slow and make sure the tracks are on the idler and sprocket, but stuck as for what would cause it to stop, in both directions.
Any ideas please?
